Changing default Revcloud Arc Lengths
adetweilerCNW6N
adetweilerCNW6N
Is there a way to change the default minimum/maximum arc lengths for a revcloud in AutoCAD 2023? I found the REVCLOUDMAXARCLENGTH command but it's obsolete.
Valentin_CAD
@adetweilerCNW6N ,
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
imadHabash
I suggest to check out those system variables in this link.
Imad Habash
adetweilerCNW6N
That's where it is indicated that these variables are obsolete
pendean
Community Legend
Community Legend
What else did you try
adetweilerCNW6N
So this changes the dimensions in the specific drawing. Is it possible to change the default min and max arclength of the system? Currently without any modifications the default are
Valentin_CAD
Sorry, not possible.
Emilio Valentin
