Changing attribute settings - unit precision
yu85.info
yu85.info
Hi. I have this block (attched). I want to change the precision of the units in the ELEV attribute from - 0.000
to - 0.00
Is there a simple way to do this?
Thank you very much
ВeekeeCZ
Well, the easier way to change it is definitely to rewrite the value in the Properties palette manually.
But.... if you have plenty of those objects... then you would need a routine for that. Eg. this one.
(vl-load-com)
(defun c:AttRound ( / s a r i e) (if (and (setq s (ssget "_:L" '((0 . "INSERT")))) (setq a (car (nentsel "\nPick an attribute to round: "))) (setq a (cdr (assoc 2 (entget a)))) (setq r (cond ((getint "\nSpecify number or decimal to round to <2>: ")) (2))) ) (repeat (setq i (sslength s)) (setq e (ssname s (setq i (1- i)))) (if (not (vl-catch-all-error-p (vl-catch-all-apply 'getpropertyvalue (list e a)))) (setpropertyvalue e a (rtos (atof (getpropertyvalue e a )) 2 r))))) (princ) )
Learn HERE how to use a LISP if you need to.
yu85.info
@ВeekeeCZ  AMAZING! It helped me a lot.
sorry for being rude... is there a way that I will be able to type the attribute name insted of picking it?
anyway it is a very nice lisp
thank you very much
ВeekeeCZ
Sure.
	   (setq a (getstring "\nTag: ")
  (princ)
yu85.info
@ВeekeeCZ  sorry but I tried to load this one and I am getting this massage:
Command: (LOAD "D:/InfraTek/LISP/attRound2.lsp") ; error: malformed list on input
thank you again
ВeekeeCZ
Sorry, one parent missing.
(vl-load-com)
	   (setq a (getstring "\nTag: "))
  (princ)
yu85.info
Perfect:)
thx
I appreciate it
