Change the title block of several sheets of the sheet set
Filipe_Cuango
Filipe_Cuango
Hello, dear friends of AutoCAD.
I have a concern.
I constantly work with sheet sets from different offices and title block changes are often frequent. I would like to know if there is a way to be able to change the title block at once for several sheets of a set?
mgalicki
You said several sheets of a set? So do you mean not all the sheets in a set?
Mark
Everything in existence was first an Idea
Autodesk Plant 3D Premium 2019
Autodesk MEP 2019
HP 3.2 Ghz CPU 16 ram
1TB 7200 rpm SATA 6Gb/s hard drive
2GB DDR3 NVIDIA GeForce GTX 680ti
HP 2311x 23" LED Monitor
Filipe_Cuango
@mgalicki
Clearly and all the leaves that belong to a set.
Change the existing title block to a new one at once
pendean
Community Legend
Community Legend
titleblocks cannot be changed out with SSM, but if they are correctly configured ahead of time to your exact specifications, you can change some of the the information in a titleblock.
So which do you want to do exactly? What long process do you use now to accomplish your task?
Filipe_Cuango
@pendean
at the moment I change the title block manually. Inserting a new title block as if inserting a new normal block in the layout
JTBWorld
This is one of the things JTB Batch Change can do. You might find SSMPropEditor useful too to update Sheet Set properties across many sheets.
Jimmy Bergmark
JTB World - Software development and consulting for CAD and license usage reports
https://jtbworld.com
mgalicki
What I do is xref my border into the sheet. And I have a block containing the title block information of fields.
Then if the boarder has a change it is changed in all the sheets that xref'd that border. So if you need to use a border that if different for say civil. you can xref the "civil border into the civil sheets.
I'm not sure what your differences in the sheets you need but you could handle it this way.
Hope I helped or gave you ideas to assist you?
Mark
Autodesk MEP 2019
