Change the shape of a path extruded object?
!AjI!
Message 1 of 12
!AjI!
Hello all,
I've got numerous path extrusions which use the shape of a rectangle along the path, to represent numerous channels.
I need to change these so that they represent cables. So I need to change the shape of a rectangle to a circle along all of the paths.
Is this possible?
Replies (11)
Message 2 of 12
Patchy
Change the shape of a path extruded object.
Did you mean change the shape of the object ?
Is this possible?
It is possible to change the shape along a path or guides if you use LOFT
Message 3 of 12
!AjI!
Ah yes, the LOFT method, however the situation I am trying to resolve.
What I have is a number of path extrusions that were born from a square shape, which then creates a long box extrusion along the path. This has been done a number of times so that there are now many long box shaped path extrusions in the drawing that form the 'network' that is being designed.
I have now been instructed to have those extrusions as circular shapes, so that they become long tubes instead of long boxes.
So as the loft command will create new extrusions that can follow different shapes along the path, I am simply wanting to change the shape of existing extrusions. (From long box to long tube).
Message 4 of 12
Patchy
Take a photo and show us.
Message 5 of 12
!AjI!
Message 6 of 12
Kent1Cooper
@!AjI! wrote:
.... I am simply wanting to change the shape of existing extrusions. (From long box to long tube).
I don't think that's possible.  I expect you would need to re-Extrude [or Sweep] using the Circle cross-section, assuming the paths are still there to Extrude along.
Kent Cooper, AIA
Message 7 of 12
!AjI!
The above needs to become circular instead of rectangular. Any easy method?
Message 8 of 12
j.palmeL29YX
I don't know a way to substitute the source of a path extrusion with another geometry.
But your current source were squares. So maybe you can fillet the four edges of your extrusion with the radius of the half length of a square side. The success of this method depends on the figure of the path's.
>>video<<
Jürgen Palme
Message 9 of 12
j.palmeL29YX
Oha. Now we have rectangles - above you wrote squares. So my suggestion above will not work.
And "Any easy method"? Not that I know a solution 😞
Jürgen Palme
Message 10 of 12
Patchy
Draw a 3dpolyline along the center of the rectangles then sweep, extrude, loft the new pipe shape.
Message 11 of 12
!AjI!
Yep that would work, thanks, but I was hoping there was an automatic method rather than having to re-draw the paths.
The image above is just an extract of a much wider network.
If there isn't then looks like I've got a bit of over-time to do 😉
Message 12 of 12
Patchy
Sub it out to others then sit back, relax 😁
