Change shape of existing viewport
MikeKovacik4928
Advisor Advisor
Message 1 of 9
MikeKovacik4928
Greetings Autocadders around the world
I want to change the shape of an existing rectangular viewport to a new shape defined by a closed polyline
I can easily recreate a new viewport to this shape, but I will lose all my settings and have to reset everything all over again.
Is there a way of just taking an existing viewport and changing its outline from the existing shape to another shape nearby which you can just select.
See embedded jpeg to give a better picture of what I am trying to do. ie modify and existing viewport's shape without having to recreate it.
Michael Kovacik
2d & 3d Autocad and Inventor designer/draughtsman
Draughting/Designing (Manufacturing) (31 yrs)
-Drawing Board (3 yrs)
--Cad (28 yrs)
---Cadkey (4 yrs)
---AutoCAD 2d & 3d (16 yrs)
---Inventor (4 yrs)
---Autocad and Inventor Simultaneously (4 years)
---(and recently Autocad/Inventor Customisation)
Authorised Autocad & Inventor Professional
Authorised Autodesk Trainer
Higher Diploma Mechanical Engineering
Autodesk Product Design Suite Ultimate 2018
Autocad 2018, Inventor Pro 2018
(personal licensed copy)
Johannesburg, South Africa
(Impossible only means you haven't
found the solution yet)
Replies (8)
Message 2 of 9
Alfred.NESWADBA
create a polyline which is your new viewport border, then select your existing viewport (with your viewport specific settings) ==> right click ==> use option "Viewport Clip" in the context menu and select your polyline.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 9
ВeekeeCZ
Use VPCLIP, select current rectangular viewport, then select (or draw) a polyline.
Message 4 of 9
MikeKovacik4928
Thanks Guys for the quick response
Mike
Message 5 of 9
m_ismailWX3NX
Hi
Is there a way to reverse from a viewport to normal lines?
Message 6 of 9
pendean
Community Legend
Community Legend
@m_ismailWX3NX Are you just trying to capture the outline?
Or are you wanting to remove the function of the viewport?
Message 7 of 9
cadffm
Or do you want to remove the clip from your viewport?
Command VPCLIP [F1]
Sebastian
Message 8 of 9
m_ismailWX3NX
No I want to convert the lines from a view port to a normal lines something like explodng the view port then you get lines
Message 9 of 9
cadffm
You want to convert a viewport, what is displaying the model space,
to just 4 (or more) lines, by get rid off the view of model space? Sounds crazy..
You can't explode a viewport, you have to redraw the shape and delete the viewport then.
Attached: VP2PL
Creates a polyline
If your really want to delete the viewport, remove the three ";;;" on the left (in this file)>
Sebastian
