Change multiple block attribute values in one click
toolbox2
Message 1 of 10
toolbox2
I have a lot of drawings, each with one or more title blocks with attributes. I need to update the attribute values with some predefined values. The same values will be used in whichever title block I select within the drawing. The title blocks are dynamic blocks.
Since the attribute and values will always be the same I thought I could customise a button to make this a one-click job for each title block that I select. Initially, I thought this could be accomplished with Lisp but then thought there must surely be an AutoCAD command I could use for this. But...I haven't found it.
The Express Tools command ATTIN looked hopeful. Put the tags and values in a text file and run the command. But how to execute this in one click? Need to pass the text file location and select the block without dialogue boxes.
I'm just not sure which way to go with this. Standard AutoCAD commands or Lisp. I'm unable to use scripts since  SCR files are prohibited on our locked down machines.
Any help would be gratefully received.
Replies (9)
Message 2 of 10
vinodkl
Hi @toolbox2
Have you tried the command "GATTE" (Global ATTribute Editor)? Using this command you can set a new value of the attribute globally inside the drawing 🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 3 of 10
toolbox2
GATTE doesn't work with Dynamic Blocks, unfortunately.
Message 4 of 10
murray-clack
If you are looking for "one click" solutions to change global title-block info (i.e. project name, client name, project number, etc.) then using the Sheet Set Manager is your best bet.
Message 5 of 10
toolbox2
It would, wouldn't it? But not for this task facing me now.
Message 6 of 10
JTBWorld
Maybe our attribute editor app JTB BatchAttEdit can help.
Jimmy Bergmark
JTB World - Software development and consulting for CAD and license usage reports
https://jtbworld.com
Message 7 of 10
RobDraw
I would use an XREF for identical information shared across multiple files.
Rob
Message 8 of 10
maratovich
Try using this - AutoReplaceCAD
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
Message 9 of 10
toolbox2
Thanks but the attribute values won't necessarily change for EVERY instance of a block, only the ones I select.
It's looking like an AutoCAD command solution isn't out there.
I found a modified GATTE command, GATTE2, on CadTutor.net. With some modification this looks hopeful.
Message 10 of 10
RobDraw
As much as some people think, AutoCAD cannot read minds. Any one click solution would require an amount of coding that might take much longer to write and troubleshoot than it would be to do the task manually.
Rob
