AutoCAD Forum
Change Mtext
14 REPLIES 14
Message 1 of 15
jostroopers
924 Views, 14 Replies
Change Mtext
If I put a single line text and use it several times and then select them all I can change them in the properties all at ones.
How do I do that with Mtext, if I select all and go to the properties they are opened one by one and you can change that.
Is there another way to do that as a single line text with the same.
Mvg Jos
Youre drawings are as good as the symbols that compleet them.....
14 REPLIES 14
Message 2 of 15
Charles_Shade
in reply to: jostroopers
Not that I have found as what you describe is the behaviour that I see.
If there is a way someone has found it but I think the nature of Multiline Text will not allow this to happen.
Message 3 of 15
For Mtext:
Height can be adjusted all at once.
Color, if by layer, can be adjusted by the layer color all at once.
Width factor can be adjusted by changing the style (if you havent forced new fonts/syles in the editor)
you can adjust the justification of multiple pieces of mtext at the same time as well.
Note: we do not use any overrides within mtext.  it's unformated.  we let our style handle it all.  if you begin to override it, you lose the ability to do some of the things noted above.
Message 4 of 15
jggerth
in reply to: Charles_Shade
If you want to change the text string, you can use the FIND command, and that will replace the old value with whatever you want.  it's a different process than changing the TEXT via properties, but it ends up in the same place.
Message 5 of 15
David_Knight
in reply to: jggerth
ahhh! OP meant the actual value of the contents, not the properties! i did not realize that.
yes, find/replace is the winner in this case.  We do it all the time as well.
Message 6 of 15
jostroopers
in reply to: David_Knight
I use find & replace but it finds nothing
Mvg Jos
Message 7 of 15
David_Knight
check the "search options" using the arrow on the bottom left corner.  Make sure that "Match Case" and "Find Whole Words Only" arent checked, and the correct text types are selected.
Message 8 of 15
jostroopers
I found out that when i in my viewport it dus't work, you have to be in the Model space.
Mvg Jos
Message 9 of 15
David_Knight
never tried in in a viewport before!
Message 10 of 15
jggerth
Well, Find will work though a viewport when the "Find where" drop down is set ot either entire drawing, or selected object (and you've highlighted/selected all the text strings visible in the viewport.    The 'Currentspace/layout' option seems to be misnamed -- and should probably only say 'Current layout'
Message 11 of 15
jostroopers
Here is a link to a short movie, because i can't get it work true an viewport.
http://www.screencast.com/t/gbiHAd6KV
Mvg Jos
Message 12 of 15
Yong.Jing
Could you upload your dwg to us? I could not reproduce the issue you met.
Yong Jing
Product Support Senior Specialist
Technical Support, CSS, GPS
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
如果我的回帖解决了您的问题,请点击 "接受为解决方案" 按钮. 这可以帮助其他人更快的找到解决方案!
Message 13 of 15
jostroopers
in reply to: Yong.Jing
Hereby the drawing
Mvg Jos
Message 14 of 15
Yong.Jing
I could not reproduce your issue with the dwg your provided. From this point, I suspect there might be some broken at your site.
Could reset settings to default?
All Programs> Autodesk> AutoCAD 2014 -English > Reset Settings to Default
Or
Go to diagnostic startup with command msconfig.exe,
Then start AutoCAD 2014 to check issue disappeared and back to Normal startup to check AutoCAD has no this kind issue.
Yong Jing
Message 15 of 15
jostroopers
I reset the settings to default and it works, then i load my own Profile and it also worked.
Mvg Jos
AutoCAD Inside the Factory
