Change layer for a large number of objects
Yuan_LiuTUF66
Observer Observer
Message 1 of 11
Yuan_LiuTUF66
Observer
Observer
Hello all, I have a dwg containing large number of objects (probabaly >500000) and they are on different layers with differenct line type etc.
Now I need to move all objects to one layer, when I select more than 32767 objects (max. you can set in AutoCAD), I cannot use the property window (MO) to change layer anymore.
So the only way I have now is to select a small portion of the dwg to make sure total number of objects not exceed 32767 at a time, then change the layer. But this takes a lot of time.
I believe there should be a better way to do this, your idea is very welcome.
Many thanks and regards,
Yuan
Replies (10)
Message 2 of 11
ChicagoLooper
Hello @Yuan_LiuTUF66
What are the objects? Points? Lines? Polygons? Text? Hatch? Blocks? If you want a good answer, you'll need to provide a good description.
Can you share your drawing file?
Chicagolooper
Message 3 of 11
doben
You can do it with the "change" command.
Select objects:
Specify change point or [Properties]: p
Enter property to change [Color/Elev/LAyer/LType/ltScale/LWeight/Thickness/
Message 4 of 11
RSomppi
Merge the layers to the desired one.
Message 5 of 11
rkmcswain
Note if you have items in blocks they will not be changed. But I suspect the layer merge idea would take care of that 😉
R.K. McSwain     | CADpanacea | on twitter
Message 6 of 11
pendean
Community Legend
Community Legend
@Yuan_LiuTUF66 wrote:
... make sure total number of objects not exceed 32767 at a time, then change the layer. But this takes a lot of time. ...
That's just a display limit so your computer does not lock up: you can select as many as you want anytime you want. Test it now. You can reduce the visual distraction by doing this https://forums.autodesk.com/t5/autocad-forum/selection-limit/m-p/5521043#M73662 (yes, set it to 0 to have no limit).
But as noted by others, there are way better ways to do what you want, LAYMRG command may be the best https://help.autodesk.com/view/ACD/2024/ENU/?guid=GUID-7D66940F-EC67-4DEC-89BC-82B887EABD6E
Message 7 of 11
Kent1Cooper
@doben wrote:
You can do it with the "change" command.  ....
... or with CHPROP, which condenses the CHANGE commmand and its Properties option into one command name, so you can go directly to which property you want to change.
Kent Cooper, AIA
Message 8 of 11
paullimapa
Here is one way to do a Layer Merge:
1. Make sure all Layers are unlocked by entering this code at the Command line:
(vl-cmdf "_.Layer" "_Unl" "*" "")
2. Open Layer Properties Manager by entering command: Layer
3. Select any Layer name and use keyboard combination Ctrl+A to select all layers
4. Deselect a Target Layer like Layer 0 by holding down the Ctrl key and Left mouse click on the Layer name
5. Hover over any of the selected Layers, right mouse click and on the cursor menu left mouse click on "Merge selected layer(s) to"
6. When the Merge to Layer window appears with the only Target layer (like Layer 0) selected click OK
7. When 2nd Merge to Layer window appears with question to continue click Yes
AutoCAD will then automatically place all objects onto the Target Layer in this case Layer 0 and delete all the other Layers.
Paul Li
IT Specialist
@The Office
Message 9 of 11
Yuan_LiuTUF66
Observer
Observer
It's a complex dwg containing all the elements you mentioned. the purpose is to "flatten" it then use it as background for a new dwg.
Message 10 of 11
Yuan_LiuTUF66
Observer
Observer
Thanks for the tip! I tried change comment but no idea why it didn't work...I tried with merge layer it works finally.
Message 11 of 11
RSomppi
You're welcome...
