AutoCAD Forum
Change hatch
2 REPLIES 2
864 Views, 2 Replies
Change hatch
hi,
Is there a way to increase the spaces between the drawings of a hatch without increasing its scale?
tks!
2 REPLIES 2
imadHabash
HI,
to increase hatch spaces you have to play with Scale factor for the hatch.i suggest to show us your case to see if there is an other way.
regards,
Imad Habash
kadmonkee
one way is if you make your hatch annotative.
you may not like the result though.
you have more flexibility if you change the scale as needed, also it is easier to manage moving forward
the other is to create a custom Hatch that you define the spacing, angle and linetype.
image shows Annotative Hatch
you can get the same result by changing the scale to 96 in this example my file (model space is set t o1/8" = 1'-0")
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
AutoCAD Inside the Factory
