change folder path for undo.ac$ file
Dario955i
Observer Observer
Dario955i
Observer
Observer
Hi, I've changed all temp folders set in the main option tab, but file undo.ac$ is still in the defult user folder
(...AppData\Local\Temp)
As in the operation I'm doing undo file is getting too big, I need to move it in another folder. Any suggestion?
thank you in advance
j.palmeL29YX
The path for this files is stored in the System Variable TEMPPREFIX.
But this variable is set to read only - you can not change it.
Jürgen Palme
