Change field to Uppercase
km4504
km4504
I am trying to find the right string to change the date field from 09 Jul 24 to 09 JUL 24. I would like the month to be all caps. Is this possible. Using 2024.
If my reply was helpful, please give a Kudos or click the Accept as Solution button below (or both).
vladimir_michl
You can do that by entering the proper formatting string - e.g.:
%<\AcVar date \f "d. MMMM yyyy h:mm %tc1">%
%<\AcVar date \f "d. MMM yyyy h:mm %tc1">%
Vladimir Michl, www.arkance.world  -  www.cadforum.cz
pendean
Community Legend
Community Legend
Or something like
$(upper, $(edtime, 0, MONTH YYYY))
and from HELP in the program
https://help.autodesk.com/view/ACD/2025/ENU/index.html?guid=GUID-F94A885A-4DA2-432B-AC1A-EB49CC6C1C7...
km4504
It worked, I just needed to change the day to two digits and the year to 2 and no time is needed.
km4504
I had to modify the string, but this is the actual format I needed. So I'll give you a like for pointing me in the right direction.
$(upper,$(edtime, $(getvar,date),DD MON YY))
