Change Default Unit Precision When Opening File
Is there a way to change the default unit precision when a file is opened?
At my job, the designers use SolidWorks and when they export .dxf files for me to QC, the unit precision is set to 0.00. I would like to be able to automatically change this to 0.0000 when I open the provided files.
Right now I use an AutoHotkey script to do this, but a built-in (or lisp) solution would be ideal.
Thanks for your time.
ВeekeeCZ
(setvar 'luprec 4)
Angular precision too? (setvar 'auprec 4)
create a acaddoc.lsp txt file with the line above and save to the Support folder to be at seachable pathes.
Also can look HERE
That's perfect! Thank you.
