AutoCAD Forum
Showing results forย
Showย ย onlyย  | Search instead forย
Did you mean:ย
change attribute in multiple drawings via excel or some other program
4 REPLIES 4
4024 Views, 4 Replies
Hello!
I have a question like this before but after some answer and help i couldnt make it.
I have googled for like 15 hours overall and this is my last way out
What i need is to extract data of mutable drawings and change for example the description in the "title block". Not the same description for every drawing, thats why I need it to be in excel.
"extract data" is good to get information out. BUT i cant get it into the drawings again...
I have tried the LISP "Batch Attribute Editor" but the problem is that one change is for all drawing. I want it to be customsable.
I have tried UpdateTitleblockV1-9 but it dosnt fit my needs.
The command "attout" and "attin" works great! BUT just for 1 drawing each time. I want to change 200 ๐Ÿ™‚
Please help me, and see attached for an example. thats the attributes i want to change.
BR Johan
Hello!
BR Johan
4 REPLIES 4
ะ’eekeeCZ
ะ’eekeeCZ
Maybe THIS app? Or have you tried other apps?
I have none experience with these apps.
in reply to: ะ’eekeeCZ
There are plenty of apps that do this, try this one
Hope this helps
Hope this helps
Thanks for the answer!
I have already tried that one. The problem for me is to edit a CSV file, all the text gets weird. Havent been able to make it work, you got any other tips?
/Johan
/Johan
AutoCAD Inside the Factory
