change a drawing view visual style
Hi
I have created views in paper space from a 3D model. But it comes in as a wire frame. The visual style seems to be locked. Is there a way i can change it to 'realistic'? Or do I have to use view ports to do this?
Apex-Solutions
Good day
You can use the shaded option, it seems to project the material through:
  • Select a created view
  • On the contextual ribbon select the edit view command
  • On the new contextual ribbon select the second dropdown
  • Select the shaded option
See attached image for reference.
Those are the only 4 options available.  If this does not give you what you need then you will need to use viewports
Regards
Marnus van Staden
Technical consultant & Civil 3D support Specialist
Prokon Software Consultants
Kind Regards
Marnus van Staden
N.DIP Civil Engineering | Senior Technical Specialist
Autodesk Trainer | Draughting Consultant
________________________________________________________________________________________________
If you find my post useful, please give me Kudos. If my post solved your problem, please accept it as a solution.
Apex Solutions Youtube Channel
john.vellek
HI @Anonymous,
Did @Apex-Solutions resolve your issue with the great suggestion? If so, please reward the post that worked with a Kudos and please also mark a post or posts as Accepted Solution(s) that resolved the issue.
John Vellek
Select the viewports and change the display in PROPERTIES
