When I use the command "Block" that specific dialog box has stopped opening? Also when I right click on one of the layout tabs and select move/copy that dialog box also has stopped opening. All other dialog boxes are working fine.
What happens if you start command:
_.BLOCK
including underscore and point, does that bring up the dialog?
Good luck, - alfred -
_.BLOCK
