Centroid Mark in Massprop Command
In AutoCAD we can get a centroid point as a number for Regions thru massprop command, But it wont show the centroid mark in it...
It is possible to show the centroid marks physically to see where the centroid is in?
imadHabash
>> It is possible to show the centroid marks physically to see where the centroid is in? <<
i suggest to use this lisp that will help you and give you what you ask. >> Click << from DDPTYPE command select proper point style.
Imad Habash
Just thought you might need this tutorial in calculating the centroid of a beam section.
Hope it helps.
