Center mark global change
I would like all of my center marks to extend past the object line of the circles. Is there a way to set the center mark command to do this for every center mark I will add I add? Or do I have to edit all center marks after they are added
Kent1Cooper
Read about the >DIMCEN System Variable< and set it to a negative value.
Kent Cooper, AIA
Hi and thank you very much. I’ll check out the link, try it in my drawing, and report my results.
