I have tried a few of the fixes mentioned on this board, my scroll wheel will not pan when pressed. I have a logitech M310 and autocad 2015. Suggestions?
Solved by Emmsleys. Go to Solution.
Hi Bbogner.
Lets start with basics.... What is MBUTTONPAN set to? 1?
Hi Bbogner.
Yes it is.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Scot-65
@Anonymous
Since MBUTTONPAN is set to 1
As a test set Scroll wheel to "Other" and then set to "Middle Button"
I am sure you have the correct setting for "Middle Button" for panning and the MS Office compatible box checked but double check just in case.
Let us know if this helps.
@Anonymous
