I created a table with formula (3rd column). The formula is just 1/2 of column B. It is showing the correct answer but there's a character of the beginning "{\C;". how can I get rid of this? Thanks. I just need the answer on the 3rd column
Solved by Cudal. Go to Solution.
Solved by pendean. Go to Solution.
I was able to fixed it. if I input formula and the data format is general then it will show "{\C;" but if I change the data format first to decimal number before entering formula then I'll get the proper format. Thank you for your input.
