cant open dwg file while autocad installed
engr_lrby
engr_lrby
Community Visitor
Community Visitor
hi
i have problem with my dwg files
i have recently installed autocad 2022 and before that i unistalled the 2024 version
when i want to open dwg file its cant open only when i have to open the app(autocad 2022) and from there (open)
the problem is (2024 autocad ) stocked on dwg and its unistalled
i cant linked the autocad 2022 with all created and exist dwg file and open them directly to app (autocad 2022)
please fine me way out to solve my problem
j.palmeL29YX
How did you uninstall the 2024 version?
Did you precise follow the instructions for a clean  uninstall given >>here<<  or >>here<< ?
Jürgen Palme
Valentin_CAD
@engr_lrby ,
Consider a Clean Uninstall of 2024.
Then after a PC Restart, associate the DWG with AutoCAD 2022.
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
jayhar
  • Right-click on a DWG file.
  • Choose "Open with" and select AutoCAD 2022 from the list. If AutoCAD 2022 is not listed, click on "Choose another app" and select AutoCAD 2022 from your program files.
  • Check the box that says "Always use this app to open .dwg files" or similar. This will ensure that all DWG files are opened with AutoCAD 2022 by default.
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
