Cannot plot XREF layers
sukishums
Message 1 of 20
sukishums
Hi all,
I have attached a dwg file into a new dwg drawing. Reference Type is Attachement.
The xref layer names are all grey out, I can still see them in model space and paper space. However, when I try to plot my sheet, all xref layers are not visible.
How do I plot it with my xref layers visible? Thanks in advance.
Suki
Replies (19)
Message 2 of 20
paullimapa
Perhaps if you thaw those xrefs layers then they'll plot?
Paul Li
IT Specialist
@The Office
Message 3 of 20
imadHabash
Since you can see them ... I suggest to check from Layer dialog the PLOT column and all other VP columns.
Imad Habash
Message 4 of 20
Kent1Cooper
@imadHabash wrote:
.... I suggest to check from Layer dialog the PLOT column and all other VP columns.
... not only for those Layers themselves, but also for the Layer on which the XREF resides.
Kent Cooper, AIA
Message 5 of 20
Kent1Cooper
If their being frozen was the problem, they wouldn't be visible on-screen.  And of those five that are not frozen, and that I assume are the Layers in question, none is set to not plot.
Kent Cooper, AIA
Message 6 of 20
paullimapa
Perhaps it's as @imadHabash posted. It could be that the xref is attached onto a layer that is set to noplot. This would cause @sukishums to be able to see the xref layers that are Thawed in Model & Layout but don't see them when plotted. @sukishums should select all layers in the Layer window and under PLOT column make sure all are set to PLOT.
Paul Li
IT Specialist
@The Office
Message 7 of 20
Valentin_CAD
@sukishums ,
Review the suggestions from this link, or post the drawing:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Message 8 of 20
sukishums
Hi all,
Yea @Kent1Cooper is correct, I'm referring to the 5 not frozen plot layers.  I checked the Autodesk Help link, it said attached or overlaid xref would be seen, but nested xref will not print or publish.
So my question is, does attached or overlaid xref print or publish?
Referring to this link in the first paragraph about attached xref, I understand c.dwg is a nested xref so it will not print or publish in master.dwg. When I plot master.dwg, will a.dwg and b.dwg be plotted?
https://help.autodesk.com/view/ACDLT/2025/ENU/?guid=GUID-0D7D1315-B58A-4BCD-9953-282FF578B144
Message 9 of 20
sukishums
The 5 layers is in an attached xref file but not nested, why can't they be plotted why I publish the master.dwg?
Message 10 of 20
paullimapa
If c.dwg is Overlayed into b.dwg and b.dwg is overlayed or attached to master.dwg then c.dwg does not show up at all. Since you posted that you can actually see the layers on the screen but they just don't plot then this is not the problem.
Paul Li
IT Specialist
@The Office
Message 11 of 20
pendean
Community Legend
Community Legend
@sukishums  share your DWG set here please: use ETRANSMIT command to capture all the XREFs and your plot table styles etc.
Message 12 of 20
sukishums
Hi @paullimapa , thanks for your reply and I understand what you are saying. I think my problem right now is b.dwg is showing but not printed when I plot master.dwg.
@pendean Thanks, here's my file.
Message 13 of 20
paullimapa
This is what I see when I open your dwg in Layout:
This is what I'm able to print to pdf:
Can you tell me what objects are missing?
I'm plotting this using AutoCAD 2025.1
Paul Li
IT Specialist
@The Office
Message 14 of 20
pendean
Community Legend
Community Legend
@sukishums wrote:
...I think my problem right now is b.dwg is showing but not printed when I plot master.dwg....
Where is that missing printed content in the file you just shared please? This looks nothing like the original screenshot you shared in your first post either.
These are the layers you have set to NOLOT: is one of them important enough to leave plotting?
And may I ask why is your layer 0 set to NOPLOT too? Most seasoned AutoCAD users never draw anything on that layer and it is best if it remains on/thawed/unlocked/printable 100% of the time too.
And what is layer 00 used for?
FYI
Message 15 of 20
sukishums
Oh yes thank you so much! @pendean It works when I set Layer 0 to plottable in Paper Space. I didn't realise it before as it's set to plottable in Model Space.
When you said "Most seasoned AutoCAD users never draw anything on that layer and it is best if it remains on/thawed/unlocked/printable 100% of the time too." - What's Layer 0 purpose and what's it use for?
Thanks guys.
Message 16 of 20
paullimapa
you must have missed what I posted way back in msg #6:
Paul Li
IT Specialist
@The Office
Message 17 of 20
sukishums
@paullimapa Yes you are right, I didn't realise xref is attached to Layer 0 and I need to set it to plot when I read your message, but thank you.
Message 18 of 20
paullimapa
You are welcome...cheers!!!
PS: Here's a link that discusses the purposes Layer 0 serves in AutoCAD.
Paul Li
IT Specialist
@The Office
Message 19 of 20
cadffm
"plottable in Paper Space" / "set to plottable in Model Space."
Plotable is a layer-property, there is no "in model" or "in paper space",
Layers and their properties are overall the same in a drawing.
_
In paper space an layout viewports you can see Viewport(layer)properties like VP COLOR, but there is no VP Plotable.
Sebastian
Message 20 of 20
paullimapa
excellent point
Paul Li
IT Specialist
@The Office
