Cannot Offset or Extrude objects in file
davidsemail916
davidsemail916
I'm trying to offset the drawing by .4mm but it won't let me.  I created the inner diameter by using the array polar command and am not sure if that' what's interfering with the offset command?  I deleted every line in between the objects and reconnected them and used the hatch command and was able to fill the object so I know that all the lines are connected, but no cigar?
What is going on?
The drawing is attached.
***TITLE EDITED FOR CLARITY***
davidsemail916
Haha, I also can't extrude the height.
What on earth am I doing wrong.  🙂
peterm
You can't offset it or extrude it because it's an array.
Explode it and turn it into a continuous polyline using PEDIT.
You can now offset and extrude it.
Valentin_CAD
@davidsemail916 ,
As another option, consider using the Method and Values to position objects in the polar array.
If your goal is a 3D model, read this link:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
davidsemail916
You are awesome!  Thank you so much
