I'm trying to offset the drawing by .4mm but it won't let me. I created the inner diameter by using the array polar command and am not sure if that' what's interfering with the offset command? I deleted every line in between the objects and reconnected them and used the hatch command and was able to fill the object so I know that all the lines are connected, but no cigar?
What is going on?
The drawing is attached.
***TITLE EDITED FOR CLARITY***
Solved by peterm. Go to Solution.
Haha, I also can't extrude the height.
What on earth am I doing wrong. 🙂
You can't offset it or extrude it because it's an array.
Explode it and turn it into a continuous polyline using PEDIT.
You can now offset and extrude it.
As another option, consider using the Method and Values to position objects in the polar array.
If your goal is a 3D model, read this link:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
