I cannot make this part a solid.. I've tried commands "UNION", "CONVTOSOLID", and "CONVTOSURFACE". None of the commands seems to serve any good. Help?? I've attached the file for anyone who can help.
Solved by john.vellek. Go to Solution.
HI @Anonymous,
I battled your Solidworks file for a bit. I found the quickest way of doing this conversion was to export the model to an IGES file, Open in Inventor and then saveas as a DWG.
Normally, I would use Smooth and then Surfsculpt or Union (which converts to a solid). I was fighting this a bit and decided to take the quick route.
