AutoCAD Forum
Cannot locate the templates folder to save a .dwt file to
6 REPLIES 6
davinder_shergill
458 Views, 6 Replies
davinder_shergill
Hello. I am attempting to save a file as a dwt. file.  However when selecting the file type a .dwt to save it is bringing up a random folder not the 'templates' folder.  I have opened the templates folder on windows explorer with all the dwt files.  The templates folder also shows up when selecting file 'new'.   However even when trying to follow the same file path for which the template .dwt's are located it is not the same and does not give those options.  Thanks
6 REPLIES 6
cadffm
in reply to: davinder_shergill
cadffm
Hi
Sounds crazy.
you have one file open.
Saveas, select .dwt
You should see the same folder as for NEW  command.
Abd if you navigate to the right folder manually, also.
Add some screenshots of you dialogs
NEW
Saveas  dwt
And windows Explorer <select your template folder>
Sebastian
Hi
Sounds crazy.
Saveas, select .dwt
NEW
Saveas  dwt
Sebastian
davinder_shergill
in reply to: cadffm
davinder_shergill
Hi @cadffm
I actually managed to save it many thanks.  just before but couldnt delete this post.
I went to tools>find. i then pasted the file directory into the 'look in folder'.  Then i clicked 'find now'.  I think i was not clicking find now before.  I located the dwt files there then override the file.
Many thanks
Hi @cadffm
Many thanks
jessica_costley
in reply to: cadffm
jessica_costley
Community Visitor
Community Visitor
Hi imm having the same issue but when i save it as dwt it dissapears and i cant find it anywhere. its not in the recentlty opened documents or in the open template
cadffm
in reply to: jessica_costley
cadffm
share screenshots (whole program window)
1. While your file is open, after you started Command: _.SAVEAS and you changed file type to .dwt
(Try to save your file)
2. After You started command: _new
Sebastian
Sebastian
jessica_costley
in reply to: cadffm
jessica_costley
Community Visitor
Community Visitor
This worked thankyou so much !!!!!
cadffm
cadffm
I asked about screenshots and you say it works, lol.
Glad to help
Sebastian
Glad to help
Sebastian
AutoCAD Inside the Factory
