I am trying to import a STEP file downloaded from a third party website, but I can't. I keep getting an import failed message.
I go to the INSERT tab, the IMPORT panel and press IMPORT.
I then set my file type to STEP, browse to the STEP file, select my file, and download. I close the background download message, and then I get the following message bubble at the bottom right:
Import Failed
The specified file is invalid or unsupported.
I have attached a screenshot of the error message, and the STEP file I am trying to attach.
I am using AutoCAD 2014, version I.108.0.0, SP1.
Thank you.
Solved by Alfred.NESWADBA. Go to Solution.
welcome @Anonymous.autodesk.com!
I was able to reproduce the import issue with 2014, however, AutoCAD 2017 worked well.
Please find the file attached.
- alfred -
Would you mind doing the same for this one as well?
Thank you!
there it is, but would have been drawing within a few minutes 😉
- alfred -
I have an even more annoying issue, no matter what file try and I import, Autocad always renders the exact same image. The same issue happens in different projects across any drawing. Download an stp file for a heat exchanger, nope renders a valve, import an stpfor of a pump, nope renders that same valve again. Import a different valve, nope renders the same valve again.
