There are three of us in this office using Acad 2018. Previously I was able to attach jpegs and other image formats using Insert|Attach. This morning, my coworkers approached me to see if I was having trouble importing PDFs. They would select the pdf but it would not appear in the drawing and there was no error message. I told them I usually don't import pdfs but attach jpegs instead. We attempted to do so on their computers but when the open file dialogue opened it had a filter hard set to point cloud files so you couldn't see or select any other file type. I demonstrated my usual method of using Insert|Attach and it worked fine. Then I tried what they were trying to do: Insert|Import|Import PDF. As in their case, the PDF would not appear. Then I tried going back to my Insert|Attach method and discovered that something changed and now I also can only select point cloud files from the Insert|Attach dialogue. I have tried it several times doing the same method Insert|Attach and it seems to work intermittently, and the rest of the time shows the point cloud file dialogue.
