A problem exploding text around an arc. My text becomes too big when exploded.
When I explode text around an arc using Home / Explode command the text width becomes a lot bigger than I want it too.
My text width is starting at 3.7655mm and when I use the explode command the text width goes to 7.6345mm.
How can I explode the text around the arc and keep the 3.7655mm width dimension?
 I have attached a few photos to help explain my question.
Does anyone know of any tutorials that would help me learn the process of putting text around an arc?
I have checked YouTube with no success.
Any help is much appreciated as I am becoming frustrated.
Thanks!
imadHabash
I try your issue and I didn't find such a problem ( see below image ) . I suggest to check the text height from  your text style ( Style command ) and make it current . if not solved please attache  your .dwg sample here ?
Imad Habash
pendean
Community Legend
Community Legend
See your other duplicate post for ongoing discussions.... .
