Cannot access AutoCAD due to Fatal Error upon startup
What should I do?
Application won't even start.
@Anonymous
Topic Title has been changed by @Tiana_Y for better findability. Original: FATAL ERROR: Unhandled Access Violation Reading 0x0028 Exception at 52114A11h
Grover_Puma
here you will find more answers. I leave the link
https://forums.autodesk.com/t5/autocad-forum/fatal-error-unhandled-access-violation-reading-0x0028-e...
ACEPTA LA SOLUCION que responde a tu pregunta, esto ayudará a otros a encontrar respuestas de una manera mas sencilla.
Si te gusta esta publicación, dale ME GUSTA.
Saludos!
imadHabash
Hi and Welcome to AutoCAD Forum,
i suggest to install your CAD update from the Autodesk Desktop App or go to Autodesk Account, and select "Product Updates" on the left frame. From there, select the correct update for the product. if not fixed try to follow this link . >> Click <<
Imad Habash
Tiana_Y
Hi @Anonymous,
Welcome to the Autodesk Community, and thank you for posting your question here in the AutoCAD forum! I just wanted to check in and see if the link @Grover_Puma provided and/or the suggestion that @imadHabash gave resolved the issue you are seeing?
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Tiana.D
Community Program Manager
Contact Autodesk Support
