AutoCAD Forum
Can you vary linetype scale across one polyline?
3 REPLIES 3
jambroselupin
359 Views, 3 Replies
Morning all,
Quick yes or no questions I suppose (I am using Autocad LT 2020 at the moment).
I was wondering if there was a way to vary the linetype scale across a polyline without using several different polylines and changing them manually. Similar to how you can vary the width of a polyline from the start segment to the end segment so it is thick at the beginning and thins towards the end.
Below is a quick example of what I mean, where I need the linetype scale to get smaller towards the end so it doesn't 'overflow'.ExampleExample
3 REPLIES 3
sorry no, not possible.
You might look for tools doing this type of hatching.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
That is a shame, thank you for the quick response however.
As I am using LT is it safe to assume I will not be able to use any tools?
>> to use any tools?
Yes, LT does not support apps/plugins. This and missing 3D is the reason for better/lower price.
- alfred -
Alfred NESWADBA
AutoCAD Inside the Factory
