Can't unhide a hidden clipped X-ref
sdwinslow
sdwinslow
Hi There,
I copied an xref in model space and clipped it to lay over a different part of a building.  I hid it in one viewport.  It disappeared in all viewports and model space.  How do I "unhide" it?  All layers are turned on, and the other xref is visible.  Any advice?
Thanks for your help!
dbroad
To show, use UNISOLATEOBJECTS.  If you want appearance to vary by viewport, place the xref on it's own layer and use vpfreeze to control per viewport visibility. Be sure to check the xref palette to see if you inadvertently erased all copies of it in the drawing.
Architect, Registered NC, VA, SC, & GA.
sdwinslow
Excellent!  Thank you!
