can't turn off snapping to dimension lines
simonquinn
Message 1 of 25
simonquinn
all of a sudden i am snapping to dimension lines, but not only to the lines but also the arrow heads and midpoints of the of arrow.  i have checked filter options and i checked ignore dimension lines and nothing.  does anyone know what is going on?
Replies (24)
Message 21 of 25
simonquinn
no, these dimensions are isolated by themselves.  but any line is able to snap to every part of that dimension.  and the" ignore extension lines" is checked and it is still snapping to the extension lines.  autocad is disobeying me, lol.
Message 22 of 25
JCKRU47
Gotcha. It seems like the issue is more of the snaps and how they are interacting. From the digging I have tried to do it seems like the only options have been addressed. Not sure why it just started acting that way for you, but at least it doesn't seem like a system breaking problem.
Message 23 of 25
cadffm
>>" is still snapping to the extension lines"
As designed, yes.
In your case the statement is right, except one situation:
NOT with snap ENDpoint.
That's the only ignore option you have and it works, also on your side.
It is snapping with other snap types or to other parts af your dimension
and this is how it works, there is no further ignore option in AutoCAD.
Sebastian
Message 24 of 25
simonquinn
i appreciate everyone's help even though this issue seems unsolvable.
Message 25 of 25
simonquinn
i figured out a solution but i don't like it cause i have to do this with every file.  open >ampowersnap >filter options:  uncheck dimensions. hit apply and close setting.  go back in the settings and re-check dimensions and hit apply.  obviously this is a bug and autodesk seems always distant when it comes to reporting bugs.
