can't turn off snapping to dimension lines
simonquinn
Message 1 of 25
simonquinn
all of a sudden i am snapping to dimension lines, but not only to the lines but also the arrow heads and midpoints of the of arrow.  i have checked filter options and i checked ignore dimension lines and nothing.  does anyone know what is going on?
Replies (24)
Message 2 of 25
pendean
Community Legend
Community Legend
>>>...i have checked filter options ...<<<
What exactly did you check? what setting?
Message 3 of 25
simonquinn
dimensions was checked.  the check mark means that will ignore yes?
Message 4 of 25
cadffm
>>" i checked ignore dimension lines"
There is no option for this, just for:
"Object snaps ignore endpoints of dimension extension lines."
Only ENDpoints, and ONLY dimension lines,
no midpoint or per filter, no arrows or extension lines filters.
You have to work well with the mouse to control the snap-points, no extra trick
Sebastian
Message 5 of 25
simonquinn
Message 6 of 25
JCKRU47
To the best of my knowledge when you have snaps turned on they will always interact with the designated points. You could try turning them all off and then turn them on as needed or just tinker until you have the one's turned on that you use most.
Message 7 of 25
simonquinn
there are 2 places i go to for these options.  one is the drafting tab in options where i check mark ignore dimension extension lines and the other is filter options in the snap settings the am preferences.  so i am all out of ideas.
Message 8 of 25
simonquinn
Message 9 of 25
JCKRU47
What are you working on that this is causing an issue, if you don't mind my asking.
Message 10 of 25
simonquinn
autocad 2018
Message 11 of 25
JCKRU47
Are you trying to move or stretch items?
Are you drawing and this is causing incorrect placement of some sort?
Are you having dimensions pull to other dimension lines or nodes?
Message 12 of 25
simonquinn
is it possible to ignore the dimension arrows?  because that's what im snapping to.
Message 13 of 25
cadffm
Right,
OSOPTIONS
For this, read my post above.
As i wrote: There are no "ignore" setting, not in AutoCAD.
Sebastian
Message 14 of 25
JCKRU47
If you turn off the end point snap it should work.
Message 15 of 25
cadffm
"is it possible to ignore the dimension arrows? because that's what im snapping to. "
Don't do that, that's the terrible Trick.
You zoom in and move your cursor to the object in question.
(share a small sample DWG with one "wrong" placed dimension - so we can talk about this one situation)
Sebastian
Message 16 of 25
simonquinn
but this just started happening.  i have always had end point on.
Message 17 of 25
pendean
Community Legend
Community Legend
@simonquinn It is easy to assume what we all wish, but if you look it up in HELP, it explains the limitations
And that's MIDPOINT, not ENDPOINT, and at the arrow, not the extension
You'll need to FREEZE the layer the dims are on or temporarily hide them using this right-click menu option
HTH
Message 18 of 25
JCKRU47
I do see what you mean. That's one of the reasons I was trying to get some clarity about what you are doing. Do you just happen to have dimension arrows near other objects you are working with?
Message 19 of 25
cadffm
Kudo for you
Or the circle-arrow and center+quad off
or or
Sebastian
Message 20 of 25
simonquinn
it is snapping to midpoint and endpoint.  i just happen to get a snapshot of what is happening.  did you want a snapshot connecting to the endpoint as well?
