Can't Select individual objects, groups everything as 1 object
Message 1 of 9
Brand new to CAD, 0 experience. I am trying to edit objects in my file but when i click on anything it clicks everything on the drawing instead and i am unable to change anything. any help would be appreciated.
Replies (8)
Message 2 of 9
sthompson1021
3 possibilities are that your are trying to select a block, xref, or group. Click on something that highlights everthing and then type the command PROPERTIES and look at the top of the properties pallet and see what it says,
Message 3 of 9
Kent1Cooper
Welcome to these Forums!
Could it be that everything is defined together into a Block or Group, or is perhaps an Xref [eXternal Reference drawing]?  Pick on something, right-click and call up Properties, and see what it says at the top of the Properties palette:
If it says "Block Reference" like that, you can EXPLODE it to separate the pieces from each other [if you're confident there's no good reason for them to be defined into a Block].
If it says "Group" [followed by a number of objects in parentheses], it's all somehow been defined into a Group.  You can change the PICKSTYLE System Variable value to 0 or 2 so that selecting something in a Group won't also select everything else in it, which will leave the Group still defined.  Or you can UNGROUP it all so the association no longer exists [again, if you're confident there's no good reason for them to be Grouped].
If it says "External Reference," that's a separate drawing file that's been brought in by the XREF command.  You can edit it in its source file, or by REFEDIT in the current drawing [again, if you're sure about why it's in the current drawing as an Xref, and whether editing it will affect other drawings].  Or you can bind its pieces into the current drawing so they're no longer coming from outside [also if you're sure...].
If it's something else, what does it say?
Kent Cooper, AIA
Message 4 of 9
Was a block reference. thanks for the help.
Message 5 of 9
ankuenyonam5
Community Visitor
Community Visitor
Hii, its a block reference but how do i EXPLODE?
Message 6 of 9
cadffm
Type in
[E]
[X]
[P]
[L]
[O]
[D]
[E]
[<enter>]
[F1]
Read more about Explode Command
Sebastian
Message 7 of 9
Patchy
It doesn't work.
I typed in [E] and hit Enter it said unknown command.
Message 8 of 9
cadffm
Merry Xmas Patchy
Sebastian
Message 9 of 9
Patchy
Merry Christmas to you and everyone who's reading.
