Hi.. I am using AutoCAD 2017 i am facing a problem in Window menu,
though i opened more than 2 drawings i can not see the opened drawings list in Window menu.
would you please show us an image for your Window menu ?
Imad Habash
Not knowing why you want to see them there, this question may be out of place, but do you need to see them there? Do you not see them as tabs along the top left of the drawing area? [This is from Acad2016, but 2017 is the same:]
i am using customize user interface so i want to select drawings from ' WINDOW 'drop down menu
you can see my user interface,
Have you tried clicking on the BIG RED A in the upper left part of the screen?
This will show you the last 9 files you opened.
what happend if if you change your workspace to another one ?
Imad Habash
I know this is alternate way to see the opened and the recent files,
my question is y con't i see in WINDOW drop down menu ?
it is same, even if i change the workspace .
here i attached an image of window menu while there are drawings open
Working with Vault. I double click to open multiple drawings. It opens another CAD application. It does not show multiple drawings that I have opened along top left of drawing are. Is there a solution.
