Can't scale my drawing to a short bond paper
emgsantosLLMHN
emgsantosLLMHN
Can't scale my drawing to 1:200 Please help and teach me how to do it. I drawn my plan with meters. Here is my file
baksconstructor
1. You should always create 1:1 drawings
2. When preparing to print, you either create a layout with a viewport at a scale of 1:200, or create a title block larger than your drawing.
emgsantosLLMHN
my drawing is created in a 1:1 scale and when I plot it into layout 3, Idk how to set it into 1:200
baksconstructor
Select the viewport.
The current viewport scale will be shown at the bottom right of the AutoCAD window. Set a new scale there.33.PNG
paullimapa
First of all I would run the UNITS command & properly change the following settings to match with Meters:
1. Length Precision should be set to 0.000 which would give you down to the mm measurement
2. Set the Insertion scale to Meters so that when this drawing is referenced or inserted into another AutoCAD would be informed that the drawing is using Meter units.
Next goto Layout1 and run PageSetup command & Modify the the following settings:
1. Change Paper Size to ISO Full Bleed A3
2. Change What to Plot to Layout
3. Set Plot Scale = 1:1
Next enter Pspace command & Zoom Extents. Now using Grips adjust the Vport to fit inside the A3 size sheet.
Enter Mspace command & Zoom Extents to see everything inside Model
Enter command Zoom Center and specify a point in the middle of the plan
For magnification enter 5xp this will give you Meter scale onto Millimeter paper units of 1:200
Zoom factor is calculated using formular: 1/0.200xp
Now you're ready to plot your drawing to 1:200
Paul Li
IT Specialist
@The Office
