Can't measure the drawings in scale on layouts
maria.m.valle
Message 1 of 18
maria.m.valle
Hi everyone. English is not my first language so bare with me. So here is my problem...
While measuring some itens from viewports on a layout I realized that everything that's inside a viewport, when I use the command distance, it shows me the real dimension, not the the dimension on the layout.
For example: Here is a layout. For context the layout has the dimension of an A4 sheet (0.297x0.210m).
 In this layout I have a viewport (inside the red line) and a rectangle that was drawn on the layout (inside the yellow line).
When I mesure the rectangule inside the yellow line (using the comand distance), autocad gives me the real dimension on the sheet:
But when I mesure  anything from the viewport ( this viewport is scaled to 1:100 )it gives me the real Dimension of the item (in this case i'm measuring the door = blue line):
Considering that the viewport is scaled 1:100 it shoulb be 0.011 not 1.1.
Note that i'm not inside the viewport; the viewport is not selected in anyway.
This is the first time this happens to me. Does anyone knows what happened?
Thank you for your help.
Note: Just realize that if i open the same file on another computer this does not happen.
Replies (17)
Message 2 of 18
rkmcswain
I don't have it to check at the moment, but last I recall, if you use object snap to pick your measurement points, from PS, you get MS results. If you eyeball it (IOW, just pick two points in the layout), you get layout results.
Message 3 of 18
maria.m.valle
Correct, if i eye ball it it gives the right measure. But again, if i open the same file on another computer, even with the object snap on, it will give the correct measure (the one scaled). so this problem only happens on my computer.
Message 4 of 18
pendean
Community Legend
Community Legend
Share your DWG file from the first image here, and also share with us the ABOUT command pop-up from your AutoCAD session too.
Message 5 of 18
maria.m.valle
I can't send the file but again. The problem is not the file because other people are able to measure it correctly. So I think it's something from program.
"share with us the ABOUT command pop-up from your AutoCAD session too"?? I don't understand.
Message 6 of 18
pendean
Community Legend
Community Legend
@maria.m.valle wrote:
..."share with us the ABOUT command pop-up from your AutoCAD session too"?? I don't understand.
Inside AutocAD, start ABOUT command then hare a screenshot of the pop-up here.
Ask your IT person/CAD Manager to explore the differences and match them up with a reimage or re-clone, or a simpler program reset https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-reset-AutoC...
Message 7 of 18
ChicagoLooper
Hi @maria.m.valle
Go to Options=>User Preferences Tab=>Associative Dimensioning=>Uncheck 'Named Make New Dimensions Associative'
Uncheck this box.
Chicagolooper
Message 8 of 18
maria.m.valle
It didn't work...
Message 9 of 18
ChicagoLooper
What are you measuring?
Are you measuring objects which have been drawn? Or are you measuring previous dimension lines?
Start with a clean drawing. Delete ALL previous dimensions.
Chicagolooper
Message 10 of 18
paullimapa
Message 11 of 18
paullimapa
also answered here:
https://www.cadforum.cz/en/how-to-measure-using-paper-units-in-paper-space-tip7392
I would make sure on the other computer when you open the same drawing to set osmode to 0 before running the DIST command in Pspace
Paul Li
IT Specialist
@The Office
Message 12 of 18
Kent1Cooper
I confess to being curious:  What would be the reason for measuring a paper distance laid over elements in the model in a Viewport?  I have never run into this issue, but only because I don't ever do that, and can't think of why I would ever want to.
Kent Cooper, AIA
Message 13 of 18
cadffm
Dist:
Mesures the projected point on layout
Dimensions:
While Dimassoc is on (2 abd default) measure between the real snaped object points.
You answered to chicago, but double check it.
Command: DIMASSOC
Value 2
Dimlinear, select both point by using object snap.
- -edit - -
>>"Considering that the viewport is scaled 1:100 it shoulb be 0.011 not 1.1."
It shouldn't, except your dimassoc is not set to 2
>>"This is the first time this happens to me."
So you are are working with the default (and prefered) setting for dimension the first time.
>>"Just realize that if i open the same file on another computer this does not happen."
Dimassoc for dimensions and Osmode(your running objectsnaps) are saved in your profile, not in the drawing.
Sebastian
Message 14 of 18
maria.m.valle
It didn't work
Message 15 of 18
maria.m.valle
">>"Considering that the viewport is scaled 1:100 it shoulb be 0.011 not 1.1."
It shouldn't, except your dimassoc is not set to 2"
I notice my mistake to late.
I have tried to change th parameters of dimassoc and osmode and nothing.
Message 16 of 18
maria.m.valle
I only realize this because I wantd to make sure that some viewports were in the correct scale
Message 17 of 18
cadffm
Really hard to follow your short answers, but I try it again.
Your PC
>>"when I use the command distance, it shows me the real dimension"
a) While dimassoc=2 and using the object snaps? This is good, right and to prefer for real object  dimensioning (for measuring in paperunits, use command Dist).
b) If your dimassoc is set to 1 or you are not using the object snaps? There is a problem
Share a screencast!
Open the sample file you used also on the second PC,
in model tab or inside a viewport, start recording (the whole program window) and
show the dimassoc setting first, in your case the setting to create stupid dimensions (1)
command DIMLINEAR, create a dimension.
switch to in Paperspace, create a dimension for the same object
Please work slowly, so we can follow all the details in this screencast.
Sebastian
Message 18 of 18
Kent1Cooper
.... I wantd to make sure that some viewports were in the correct scale
Just pick the Viewport boundary and look at its Properties.
Kent Cooper, AIA
