Can`t make a section view of a 3D model in layer.
edgars1studens1
Message 1 of 15
edgars1studens1
Hello everyone,
so I have this problem with my 3D model. Basically when I try to make a section view of my 3D model and after I press enter it just does not appear. Like I can see the model sectioned (in colors) but then I hit enter and it dissapears. I noticed that it has something to do with the spring in the middle of the model, because when I remove it, it sections perfectly. I dunno what could be wrong with the model and I am just a beginner.
I added the 3D model file.
Thanks 🙂
Replies (14)
Message 2 of 15
nikm42Q9N
you don't want to break up the model to make different views this makes drawing in 3d kind of pointless. in paper space try the view base command. Using this you will be able to show front, back, side section...etc with just the one model
Message 3 of 15
edgars1studens1
But I really need to show inside/inner workings of the part (valve)
Message 4 of 15
nikm42Q9N
youtube view base command you can make any section or view you want . FYI i know you might be limited in software but you should really look into Inventor if your work is going to consist of things like these
Message 5 of 15
nikm42Q9N
Message 6 of 15
edgars1studens1
Thanks, I know for work I use fusion 360 and SW but this is for my school
program and they want us to use 3D in Autocad
Message 7 of 15
mgarcesUX9HW
Hi Edgar,
use autocad view base you can do plan ,iso, section and elevation and link to model as well, ive done this from your file in less than a minute of course if you have a template already
Message 8 of 15
edgars1studens1
Is this made in the layer tab, because it looks just like I need it to be. But I quite don`t understand steps on how you made it. But still big thanks for the insight :))
Message 9 of 15
edgars1studens1
Tried it and basically it just crashes if I try insert it, but when I remove the spring it works. Have no idea why is that.
Message 10 of 15
nikm42Q9N
try the FlatShot command
Message 11 of 15
mgarcesUX9HW
it could be your system, the process will require a lot of memory i think
Message 12 of 15
mgarcesUX9HW
when you create viewbase it will automatically create layers then from the layers you can customize your color, linetype, etc see below snapshot
Message 13 of 15
edgars1studens1
Oh understod, I get this far, but I realized that the program is not letting me make different views. Like I can only add the first view and thats all, it crashes. Even if I try to make a section for the one view I can add it just crashes (not like throws me out of the AutoCAD but like frezes and doesn`t show the view/section I wanted to put).
Message 14 of 15
nikm42Q9N
Yea i know your pain, view base works great on my work computer but on my home CPU not so much. One thing you can try is making sure your grapics are running on Direct X 11. This helped my allot with CAD hang ups
How to make AutoCAD run with DirectX 11 | AutoCAD 2021 | Autodesk Knowledge Network
Message 15 of 15
edgars1studens1
Thanks guys for the help, and quick responding. I tried everything and in the end I looked at my task manager and it looked like AutoCAD is using too  much of my system ram (16gb). I restrated the computer, opened AutoCAD on it`s own without different background programms (like Chrome ect.) and everything worked fine.
But yeah huge thanks to all of you guys, great community. 🙂
