hi everybody
Am I still a valid member of the education community and eligible to use the free student license/web services.
but when I tried to download AutoCAD 2014 .. got this error:
Location Error - Download Request
This download is not available in some countries.
I'm living in Malaysia. so what I have to?!!
many thanks in advance..
Solved by philip.s. Go to Solution.
Our apologies for the inconvenience @adel077. Can you please download the software from our VA and run as a trial for the time being while we investigate?
Just wanted to follow up on this one and in case you haven't already, the workaround here should be to download as a trial and then activate from the serial number that displays in the Education Community.
Where you able to activate your license?
hi,
im also from malaysia and facing the same issue. i tried looking for the 2014 trial but couldnt find it. there is only 2015 for windows and 2014 for MacOS..
do we have a solution yet for the issue above?
thank you..
Hello @Anonymous!
As mentioned in the previous post, you can access current + previous version software directly via the Autodesk Virtual Agent.
