Can't Double Click To Edit Text in Table
CoryYundt2
CoryYundt2
I recently upgraded from AutoCad LT 2019 to 2020. I can no longer simply double click on a cell within a table to edit the text.
I have checked set DBLCLKEDIT =1,  as well as enabling Noun/Verb Selection.
Is there a setting that I have overlooked?
ennujozlagam
you can refer to this LINK and see if helps. thanks
JBlissZBS
Community Visitor
Community Visitor
I had the same issue.  I ended up clicking a bunch of times until it popped up.  I think it's a computer speed thing...not ideal, but it ended up working.
sandrewsM7TZD
Observer
Observer
I had this issue because I had multiple selections or whatever turned on.  I hit Ctrl W and turned it off for a moment and it allowed me to do it
manieshkumar.suresh
Check this step try the following in order to ensure double-click editing is enabled:
  • Enter DBLCLKEDIT on the command line and change the value to 1.
  • Enter PICKFIRST on the command line and change the value to 1.
  • Enter OPTIONS > User Preferences tab > Priority for Coordinate Data Entry > Make sure "Keyboard entry except script" is selected.
  • In the properties or text style, make sure the width factor is greater than 0.
Maniesh Kumar Suresh
Escalation Lead
If this information was helpful, please use the Accept as Solution function — it helps other users.
