Can't delete layers
Can't delete layers
leahTMHX9
Can't delete layers
leahTMHX9
Hi there,
I've tried deleting all the objects out of the top 12 layers of this file, but the layers won't delete.
Any idea why?
Thank you!
cadffm
>>"Can't delete layers" and you shouldn't delete Layers! Just purging 🙂
Q: What is your Productname and Productversion? Check it by Command ABOUT.
In newer Versions: Use command PURGE , Tab [non purgable item]
to check where the layers are refered
In your case: 11 Layers a refered by blocks
Solution: Purge blocks, then purge Layers
But why nit PURGE ALL items should work?
and Layer12 "S-BEAM" is the current one, set another layer as current, for example Layer 0, so S-BEAM will also purgable.
Sebastian
DumR0
HI
Use comand: laydel
pendean
Community Legend
Community Legend
All your layers are gone now (see attached): get familiar with PURGE (you had over 490 blocks that needed to be gone), LAYDEL and LAYMRG commands when you are trying to get rid of layers. HTH
