Can't click-drag to move object
Searched the forums for the past hour looking for a solution and haven't found anything, here's my problem:
I can't click-drag to move an object anymore. I could this morning, then at some point that functionality vanished. When I click and drag an object a circle with a line through it appears instead of moving the object. Using AutoCAD 2018 on a PC. I've put PICKFIRST, PICKDRAG, etc. to their preferred values based on comments I've seen in other threads and nothing has worked. The MOVE command still works but it's nice to be able to click and drag objects quickly when needed.
Johanna_Esteban
Hi @Anonymous,
Could you please share a screenshot of this configuration?
Please go to Options, and Selection tab.
Thank you.
Johanna Esteban
Autodesk Expert Elite | Autodesk Certified Professional | AutoCAD Customer Council (Beta Tester for Windows & Mac)
¿Te ha parecido útil este post? ¡Dame Kudos! 😉
Si ha sido resuelta tu inquietud, selecciona 'Marcar como solución' para que otros usuarios la encuentren fácilmente.
pendean
Community Legend
Community Legend
Did you restart AutoCAD or Windows yet?
afinemann
This has happened a few times to me. Restarting the computer does the trick every time
Alexander.SanchezVBJ2Z
I am interested in self-inflicting this bug to my AutoCAD. Please provide more information to replicate!
cadffm
see post #4, it's temporary (and we don't know a straight way to force this memory issue on your side).
What you can try: Open a file with lot of objects and click-drag for an hour.
PS: If I am right: Search for your real goal, you are not the first one with this unwritten wish 😉
Sebastian
