When I try to change the properties of my plot style, CTB file, i run into an issue.
I have a mask layer, with an assigned color, so I can see where I have a whiteout , without it being white in the model space. But when I try to assign 255,255,255 in my plot style - it changes to "use object color" I can use 255,255,254 - but as soon as I change it to 255,255,255 and clickok in the dialog box, it goes back to "use object color"
Anyone knows whats happening?
I used to be able to do this
255,255,254 should work, but if not, take another color - also the object color is okay,
but change the SCREENING to 0
Sebastian
255,255,254 does work - im just trying to figure out why I can't select "pure white" anymore.
What does the screening do?
I'm editing the CTB outside of CAD - but the same thing happens if I do it in AutoCAD or try with a new CTB
Hello @kfa4CD2E
The drawings have to be set up to use named plot styles (STB files). Click here
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly. If your issue persists,
Please give me a bit more detail on this issue so we can continue to work towards getting this solved.
Revit Architecture Certified Professional
Thanks You
JAYHAR.M.J
Team Leader
Helpful Links: Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | AutoCAD randomly crashes or freezes
I guess you missunderstood the problem (the opposite direction,aci should print as 255,255,255)
In STB plotstyletables, you have the same problem.
May i ask why you go this way and not the smart usual way?
Set your wipeout to the color of your choice to see the wipeout while working
and then set WIPEOUTFRAME to 2, so it will not plot. Help[F1]
Sebastian
