Can't change mouse click behaviour
phliberato
Message 1 of 13
phliberato
I have changed the behaviour of mouse wheel click+ctrl to 3D Orbit Transparent like the mouse wheel click+shift event using CUI command, but it didn't work. Anyone has some cue to fix it?
Replies (12)
Message 2 of 13
pendean
Community Legend
Community Legend
Mouse button settings are controlled in your Mouse Driver, no where else.
Assign it to a function available, then set that function in AutoCAD to get what you want. Start exploring, post back if you get stuck.
Message 3 of 13
TheCADnoob
Are you working in the same work space you changed?
CADnoob
Message 4 of 13
phliberato
I think so, because when I remove the default behaviour of shift+wheel it works.
Message 5 of 13
john.vellek
Hi @phliberato,
I agree with Dean that the best approach is to do this is through the mouse driver itself if possible.
John Vellek
Message 6 of 13
phliberato
Hello John Vellek,
Could you take a print of this screen? I'm not getting to find this approach.
Thank you
Message 7 of 13
john.vellek
Hi @phliberato,
What kind of mouse do you have with your system?
John Vellek
Message 9 of 13
john.vellek
Hi @phliberato,
Did you download and install the Microsoft software for the device? I believe that once installed it should give you some options/settings that you can set up.
John Vellek
Message 10 of 13
phliberato
Yes, I did this but I couldn't find this option. May you see the mouse's driver screen?
Message 11 of 13
phliberato
Message 12 of 13
john.vellek
Hi @phliberato,
Is the bottom option to make Custom? Also, on the right hand side for Application Specific Settings are there any choices available there?
John Vellek
Message 13 of 13
phliberato
No, I have tested both but without any outcome. But it's ok. We are going to buy another mouse and then try as soon as possible.
