Data extraction with same value
Hi, Im from Panama.
I need some help using the data extraction command.
I have a block that has several attributes, 4 of them has the same value (6.00) and same tag name ("LR") but when I performed the data extraction it's separating every tag in "LR", "LR(1)", "LR(2)" and "LR(3)".
I need to extract the tag name that has the same value, so at the end I would have:
Tag name = "LR"
Count = 4
Value = 6.00
I attached a picture of what the data extraction gave to me and the dwg.
Hope someone can helped me.
Thanks.
Civil Engineer
Sherill Teng
Alfred.NESWADBA
Your block definition contains 4 attribute definitions with the same name, that has always to be avoided. Give them different names and in the DATAEXTRACTION you can then uncheck the second to 4rth attribute.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
ara_neresesian
HI
Well ,I made some changes on your block and got what you want,
If you want that report you have to make 4 attblock in side a block .
you can see the dwg file (my modification )maybe it will help you.
Good Luck,
Please select the Accept as Solution button if my post solves your issue or answers your question
