AutoCAD Forum
Can not move from one layer to another layer in Autocad 2019.
5 REPLIES 5
493 Views, 5 Replies
Hi, I can't move from one layer to another layer in Autocad 2019.
Command: '_.-LAYER
Current layer: "Postes"
Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile/Xref]: _OFF
Enter name list of layer(s) to turn off or <select objects>: =Postes sin Usar
please, helpme.
Tags (2)
5 REPLIES 5
Kent1Cooper
Use the Set option to Set another Layer as the current one.  [Your command-line snippet involves turning a Layer Off, but that's not necessary when Setting a different one as current.]
Kent Cooper, AIA
s.borello
What happens when you open layer properties and double click your desired layer?
in reply to: s.borello
nothing, I want to move some objects from layer (A) to layer (B), it was a success. but when I want to turn off the layer I can not turn off, it's as if I had not passed it to layer (B) and this is the message.
Really want layer "Postes sin Usar" (the CURRENT layer) off? <N> _Yes
* The file was created in autocad 2018 and now I am working in autocad 2019 student version.
Kent1Cooper
What are the objects?  If they are Blocks, and if their parts  were drawn on some Layer other than 0, you would need to turn that Layer Off, not just the Layer on which the Blocks are inserted.  Or, if you Freeze  the Layer where they're inserted, rather than turn it Off, the Blocks will disappear regardless of the Layer(s) of their component parts.
Kent Cooper, AIA
pendean
AutoCAD Inside the Factory
