Can I pause a command to initiate a keyboard shortcut
cory
Message 1 of 15
cory
I have several keyboard shortcuts that are set for different zoom operations.  I would like to start the line command to create a line, pick a point to start my line and then initiate my keyboard shortcut to zoom in our out etc.  I can zoom in and out and pan around with my mouse but if I try to initiate a command such as "shift z" for zoom extents it just ignores me.  If I am not in the middle of a line command my shortcuts work fine.  Is there a way to start my line command, pick my point or intersection and then pause that command and hit "shift z" to zoom extents without loosing my line?
Replies (14)
Message 2 of 15
Kent1Cooper
If you define your shortcuts to initiate 'Zoom [with the preceding apostrophe, to be "transparent"] commands, they may work, though I haven't tried that by way of keyboard shortcuts, so there could be something about those that doesn't allow that.  It certainly works in other menu-pick instances.
Kent Cooper, AIA
Message 3 of 15
john.vellek
Hi @cory,
The Apostrophe is the key as Kent1Cooper suggested.
For instance, I start the LINE command and pick the first point. When prompted for the second point I enter 'Zoom and have the option to enter Extents, window, etc. and then it returns to the line command.
John Vellek
Message 4 of 15
cory
Thank you guys this works very well...but... does anyone know a way to do this without hitting the apostrophe first.  I would like to be in the middle of my line command and only hit, SHIFT Z, to zoom extents and not lose my line.
Message 5 of 15
Patchy
It can be done in CUI with Shift+any F keys with macro :   '_.zoom _e
Why not Double clicks the middle mouse button? it's for zoom extents.
Message 6 of 15
Kent1Cooper
Something is defining what SHIFT Z invokes.  Get into that definition, and add the apostrophe there.  That's what I meant in Post 2 by "...define your shortcuts to initiate 'Zoom [with the preceding apostrophe, to be "transparent"] commands...."
Kent Cooper, AIA
Message 7 of 15
Kent1Cooper
That covers Zoom Extents, but re-read the first sentence in Post 1 -- they have shortcuts for other Zoom operations, too.
Kent Cooper, AIA
Message 8 of 15
Patchy
Why don't you try to make Shift+Z  and make it work
The answer is there Shift+ F key
See that answer.
Message 9 of 15
cory
I can use the middle mouse button for zoom extents but I have other zoom shortcuts that I would like to work as well.
 I do have something odd happening that I'm not sure is an AutoCad issue or a computer issue.  When I begin a keyboard short cut such as, SHIFT Z, or SHIFT X, etc. I have to press the Z or X very quickly. If I press and hold for any amount of time, even for a second, the function does not work.  I almost have to press SHIFT and hit the letter as fast as I can and it works perfectly.
Weird.... any ideas.
Message 10 of 15
cory
I'm sorry I wasn't quite following you at first the apostrophe is there and it seems to be working well.  I didn't know what you meant by "transparent"
Message 11 of 15
cory
I have no idea what your saying
Message 12 of 15
Patchy
Shift key+  a letter    NEVER WORK
Using Shift key + the F key WORKS
so go to CUI and do this:
Message 13 of 15
Kent1Cooper
@Anonymous wrote:
....  I didn't know what you meant by "transparent"
See this [from Help for 2016 but the same is true in other versions] about halfway down under the heading "Interrupt a Command with Another Command or System Variable."  'Zoom is one of those that can be used that way, and 'Layer, and 'Snap, and some others.
Kent Cooper, AIA
Message 14 of 15
cory
Patchy
I see what your saying now.  By F key you mean any of the functions keys.  I thought you literally meant the letter F key.
Thank you for your persistence.
Message 15 of 15
Patchy
Sorry about that, the F function keys is what I meant.
