Converting an AutoCAD drawing to OBJ format
Message 1 of 11
How can I convert my AutoCAD 3D Models from DWG format to OBJ format?
I don't find it in the export options.
Replies (10)
Message 2 of 11
There was, at one time, an OBJ exporter in the Exchange App Store.  IIRC, I had to try out a couple of different ones before I landed on one that worked for what I needed.
Message 3 of 11
Alfred.NESWADBA
welcome @Anonymous.autodesk.com!
Not directly possible, what software are you using to export your data to? Maybe you'll find other formats (like FBX, IGES, SAT, STL) which can be exported directly from AutoCAD.
The way you can go is to install the (free) FBX Converter (>>>click<<<), export your drawing as FBX and use the FBX Converter to convert it to OBJ.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 4 of 11
JDMather
You might be able to do this by uploading your file to your myhub.autodesk360.com and then exporting in desired format.
Can you attach an example *.dwg file here for testing?
Message 5 of 11
Alfred.NESWADBA
Don't you need a license of Fusion 360 to do that?
Plus (for me important) in that case the data is transferred to the cloud just for conversion, so double check if there might be security risks before going that way.
- alfred -
Alfred NESWADBA
Message 6 of 11
JDMather
Well, I just ran a experiment and not sure that is going to work anyhow.
I have to get some other work done before I can experiment more.
As far as security - virtually all of my financials are done electronically.
Message 7 of 11
I found a solution. The company I work for has access to 3D Studio Max which, if you know where to look and which buttons to push, allows you to import DWG files and export to OBJ. Wasn't easy to figure out.
Thank you all for your suggestions.
Sincerely,
Michael E. Marshall
Beyler Consulting, LLC
phone: 253-301-4157 fax: 253-336-3950
cell: 253-227-8508
office: 7602 Bridgeport Way W., Ste 3D, Lakewood WA 98499
www.beylerconsulting.com
mmarshall@beylerconsulting.com
[cid:image001.png@01CFF81A.4AC24EC0]
Confidentiality Notice:
This email message, its content including images and attachments, are for the sole use of the intended recipient(s) and may contain confidential, privileged, or proprietary information that is exempt from disclosure law. Any unauthorized review, use, disclosure or distribution, in part or in full, is prohibited. If you are not the intended recipient then please immediately and permanently delete/destroy all copies and versions of this email. Contact Beyler Consulting at 253-301-4157 if you have any questions.
Message 8 of 11
Thank you Alfred,
I had forgotten about the FBX Converter.
Message 9 of 11
Thanks JDMather,
Did not know about "myhub.autodesk360.com"
Got to try it out.
Message 10 of 11
I tried doing that. But there is no export option showing for me. Can you please help. Thanks.
Message 11 of 11
vinay.elumalai
Community Visitor
Community Visitor
i tried now, it doest not work
