Message 1 of 14
Using ACAD 2023. I know the names of almost all the blocks I want to insert. Is there a way that I can simply type "I" (enter) then type the block name in the command line instead of having to type the name in the separate block window? The block I choose from the window enters at a random point so I must then pick the block at it's insertion point and move it to the desired location. I liked the simple way I inserted blocks in ACAD 2019. These few extra steps are very frustrating. Is there still a way I can do it the old way without going thru the block insertion window??
PO'D
