Is there a way to change the style of the standard dialog box for file browsing (file open, xref, etc) so that it matches the style from File Explorer and other programs? Specifically I want to be able to copy a path in the File Explorer address bar and paste that path into the dialog box of AutoCAD. Since AutoCAD uses an older style without an address bar I am forced to either rely too heavily on quick access folders or manually navigate to my location (which often times is buried deep in layers of network folders).
I've been using AutoCAD for a really long time and it's always been this way but I'm just curious if the software was updated at some point to provide an option for this and I simply missed it.
Solved by Ryan_MooreWKNYJ. Go to Solution.
Solved by VincentSheehan. Go to Solution.
You can paste the file path in the File Name box then press enter/open. That will take you to the location.
Fantastic. I would have never thought to paste the file path in the file name box. Much appreciated!
